Likely the valve body needs to be rebuilt.
You did not say how many speeds your trans has or what trans is in the car. Usually as the valve body and solenoids wear and as the trans fluid warms up, it starts to shift downshift hard and may do crazy upshifting. The warmer the fluid, the crazier and harder the shifts.
Suggest you pull the trans pan and see how much trash is in the pan. If the pan is clean and the trans does not leak, then it is pretty much a no brainer to rebuild the valve body.
Suggest if you go for a valve body rebuild, use YOUR current one. Price is probably in the $650 range plus shipping and you need to factor in fluid and labor. The hardest part of the job is the small solenoid connectors, releasing them without breaking the solenoid caps. I did not break anything, it took a LONG time to figure out how to get the connectors to release.
Johnny at PC Transmission did my 09G 6 speed Tiptronic and they rebuild my valve body I shipped to them. Sent it out from the East coast on Saturday, had it back in my hands on the following Friday.
