I have a 2.0 5 speed 2000 NB with 115k on the clock and it has been great (it even has heat!) until two days ago.
I was driving home and a block from my house just after I got into 3rd gear I lost almost all power. I limped home and just checked the codes today.
Here is the list:
p1255
1 17663/P1255 - Engine Coolant Temperature Circuit (G62): Short to Ground
p0302
1 16686/P0302/000770 - Cylinder 2 Misfire Detected
p0303
1 16687/P0303/000771 - Cylinder 3 Misfire Detected
p1472
P1472 17880 EVAP Emission Contr.LDP Circ Short to Ground
p1425
P1425 17833 Tank Vent.Valve Short to Ground
p1225
P1225 17633 Cyl.1-Fuel Inj.Circ. Short to Ground
p1226
P1226 17634 Cyl.2-Fuel Inj.Circ. Short to Ground
p1227
P1227 17635 Cyl.3-Fuel Inj.Circ. Short to Ground
p1228
P1228 17636 Cyl.4-Fuel Inj.Circ. Short to Ground
p0300
1 16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
I read about the fuel pump relay so I pull it open and cleand the contact points (look new now) and put it back in. No diffrence.
The car still runs but stumbles at idle till its warm then is ok-ish but if you give it and gas it stumbles until you ease up. Then seems ok-ish..
The only thing I've done in the last week was pull the MAF and clean it with electrical cleaner and was running fine the other day..
Random side note.. Its running a little better with out the MAF plugged in and oddly I don't get a light for that!?!?
I know this is a lot but any input will be greatly appreciated!
Here is the list:
p1255
p0302
p0303
p1472
p1425
p1225
p1226
p1227
p1228
p0300
