I feel kind of bad, making my first post a beg for help, but I'm kind of stumped. I've been browsing this board since I bought this, my first VW, a week ago. I'm just going to copypasta the video description to here... and, like it states, I had oil pressure problems from day one, which I've fixed. I plan on driving the car to my father-in-laws home garage and putting it on jack stands, searching for some kind of loose or torn hose.
2000 Volkswagen Beetle 1.8T Odd Noise No Power - YouTube
"Recently had oil pressure problems (clogged oil pickup), fixed said problems but during test drive engine makes this noise and has little to no power. Noise does not change based on vehicle speed or engine rpm, but seems to coincide with spool of the turbo, and as I said car has no power as if I'm getting no boost whatsoever. Noise occurs when sitting still while revving the engine, or going down the road while under load. Car is a manual, if that matters. Car didn't have much power before oil pressure problem, but I was told beforehand that these didn't have much power to begin with (I just purchased this car), and now has much less and the noise wasn't present before and appeared half-way through the test drive, not from the start.
I'm assuming a bad boost leak somewhere, in such a way that the escaping air is making this noise.
Edit - The noise stops when I let off the throttle, regardless of engine RPM or vehicle speed."
Thanks for any help you all can offer. I love this board so far, full of friendly, well-read people.
EDIT - Forgot to add that the noise isn't always as loud, sometimes it goes in and out, but the power doesn't change. To put it into perspective, while the car was apart, I drove my dads 3cyl Geo Metro (he's a mileage freak), and I can quite honestly say the Geo had more power than my car does now.
