When there is a leak at the water pump isn't it usually a slow leak? My question is mine I can fill the reservoir and within 2-4 min it's completely poured out. Is there anything else up in there that can leak that fast. Car is an 2002 2.0L. Thanks for any help I need to get this figured out and get my car back running
Generally with water pumps; how fast it leaks out of the weep hole, depends on how worn the water pump is. When the bearing gets worn to a certain point; it will start leaking and when really gets worn out; it will continue to flow out of the hole continuously. If you're trying to determine where it's leaking out of; I would pressure test the cooling system; you can buy a tool that will do this from places like Harbor freight (the HF kit; comes with a adapter that works with the New Beetle). Pressure testing the system; will make pin pointing the leak, obvious! I always; pressure test my cooling system for leaks, after I work on the cooling system and this confirms, everything is fully sealed after the repairs are compelete.
Radiator Pressure Tester Kit
Pittsburgh Automotive - Item#69258
http://www.harborfreight.com/radiator-pressure-tester-kit-69258.html
Ok I'll look into that thanks. Its also not starting now with the epc light on. Just keeps cranking even with trying to jump it. I replaced a leaky coolant flange last week and now this urrr.
How many miles on the car? Has the timing belt/water pump ever been done?
It's got 145,000 I bought it from a lot. No service records. So I'm gonna change the belt and all now as well
Started digging into this while I'm waiting to get parts and noticed when the water is poured in it is leaking from behind the timing belt tensioner pulley??? Is this a head gasket issue I have no other signs of failure
