Having a no crank issue with my 02 NB turbo S. It's been fine. Came home from a short trip and went out an hour later to start, and nothing. I did note a new sound while driving on the previous trip something on drivers side kind rattling/clicking faintly.
For grins, I hooked it up to charger for an hour while I ate dinner. I don't think it's the battery.
Key ignition and press clutch in I can hear the clutch switch click, but nothing else. No sound from the starter solenoid. If I continue to hold clutch / start position, I hear some electrical clicking (not like a relay -- more like shorting) coming from under the dash.
Anyone had similar experience?
Thoughts include the alarm module, which gave me problems and got disconnected on my mk3 car.
Is the immobilizer light flashing and have you scanned the car for codes? From what you are saying; there is no activity from the starter at all (not turned over at all). My first thought; would be the possible failure of the starter switch or wiring going to the switch; it is common for the switch to fail or the wiring to the switch ends up getting melted. You could pull the starer and have that tested; that would eliminate that as a possibility, if its ok... I would check out the starter switch/wring. I just had my starter go out; it was the original and I had over 70k, so it would be about time for yours to do too! :) I bought a rebuild Bosch starter and it has worked excellent so far; don't buy aftermarket junk, get the real oem Bosch and historically, they have been excellent. Hope this helps; keep us posted as your troubleshooting and repair process, progresses. I have also; been struggling with a starting/immobilizer problem; after taking my steering column apart; I found the starter switch, wring harness, plug to be melted; I got all the parts from the dealer and fixed that problem.
