I have a 03 that won't start. I put a crank sensor in. It has no spark to the plugs. I tested the injector with a test light. It has a very dim light with the key off on the hot side. It is a little brighter with key on. The ground is very bright when tested. I get no blinking when hooking them together and turning engine over. I have no codes or light on the dash. I have fuel pressure. It is still in time. I am thinking maybe camshaft sensor
Discussion Starter #2
I just tested the cam sensor. It has 12 volts to one wire 5 to another and the last wire is ground. I took a voltmeter tested the 5 volt wire. The way I understand it the voltage should have changed. It went from 5 volts to 4.99.
