Hi all:
I bought a '04 NB Turbo Convertible in January. I noticed that the auto top function was kind of funky, but my hubby's an engineer so we decided it was a good enough deal that we'd buy it and he could fix it.
We've read through all the threads on this forum about convertible top issues so we're familiar with some of the causes of intermittent tops. But in his attempting to diagnose and fix the problem, it went from intermittently
working to not working at all.
And just saying to heck with it and dropping it manually isn't working as 1) I weigh like 100 lbs and I can't lift the top on my own, and 2) the thing screams like a banshee when you drive it that way, because the sensor thinks the top isn't dropped right. Sigh.
Here's what it WAS doing:
- top would start to drop, then pause/get stuck/then continue until it was down
- top would be stuck down for several minutes to an hour before the automatic switch would come back to life
- top would pause and chug upwards until it was back closed
- note: wings were found broken off under the spare tire post-purchase (gotta love shady used car salesmen).
- the little retractable slider plastic pieces sometimes get stuck and don't engage/slide, and you'll have to manually push them out of the way for the top to raise.
Here's what we've done:
- cleaned the little metal push button switch in the right top windshield frame (as suggested)
- done a full window reset
- checked the hydraulic fluid level in the motor in the back
- checked all of the fuses in the panel
- tempted to pull the sliders off since they still get jammed/in the way, but haven't done that yet
Here's what's happening NOW:
- the automatic button doesn't do anything, except drop all the windows 1" if the top latch is disengaged.
- if I go through the motions to drop the top, I hear a whirring noise from the motor in the trunk, then I hear nothing.
- The top light stays solid orange
- Window resets off the master switch do not make the automatic top button do anything but drop the windows (used to work sometimes, now it's none of the time
- if I drop the hydraulic switch and lower the top by hand, the light is solid at a stop, or when driving, it's blinking and screaming at me randomly from 0-30mph (it it because I have to do something to latch/secure the top down somehow?)
Any takers on this one? I've ordered a VAG-COM and it's on its way, but I am assuming that I've got top up/down sensor replacements and maybe even a motor to contend with at this point, and who knows what else in terms of gremlins.
THANK YOU for any help!!! Super appreciated. It's 80-90 degrees in Cali, and so far I've just cranked the radio to cover up the banshee while driving
but I want to fix it right... otherwise she's going up on Craigslist
