06 conv. DRL disable help
Ok I am new to the NBC. After reading much info about the daytime running lights I think it wise to disable. I looked through the opening gained by removing the trim around the fuse block but only see a couple of relays and they are deep inside. No way to reach from this location. I need someone that has knowledge on the 06 conv that can tell which relay, where it is located, how to access it, and then what to do to the relay to disable the DRL. I am very handy with tools and have worked on relays many times. I just need the knowledge that I know someone has tucked away that has done an 06.
