drove my tdi about 30 miles yesterday, gettting off the expressway coming down the exit ramp after taking it out of gear, it wouldn't go into any gear, finally get it into 3rd and manage to get through the red light going slightly uphill. As you release the clutch, the car seems to vibrate some (not the clutch pedal). checked the brake fluid, it was about the same distance from MIN to MAX below the MIN, so added more fluid, have not drove it much today since adding fluid.
PS it rolled 90K last weekend.
No NB Yellow Trifecta :(
Off the top of my head the shake or vibration could be an indication of the clutch slipping; also the inability of getting it in gear could be related to low brake fluid or a bad pressure plate not releasing the pressure on the clutch plate.
