Can anyone give me the part number for the crush washer seal whatever you call it for the transmission drain plug on an 09g transmission? Vehicle is 2008 NB. I swear I found it here before but can't find it now, sometimes I'm just a little slow...
Thanks. I did some digging after I posted and came up with that number and another one, 09d321181b. I can find sites saying either one of them works/won't work. Lots of misinformation out there. Do you happen to know what the difference is between the two?
I don't know, i just did a fluid change on a 09G and used a blauparts trans fluid change kit, it came with a crush washer but ended up using something else, like a copper washer instead. Call your local vw dealer with your vin # and they should be able to confirm the right one for your particular car.
