When servicing my '05 1.8T with the 09G trans, the fill tube snapped off and I wasn't able to recover the tabs that broke off...
Anyone know the best way to recover the plastic tabs from inside where the fluid fills up the trans pan?
  1. TIA!🍻
    250391
BigJon,
Did you ever get the plastic out of the transaxle? I just did the same thing today.Two tabs broke and only one dropped into the pan. I tried pumping fluid into the hole, but no plastic dripped down.
  1. TIA!🍻 View attachment 250391
BigJon,
Yes, but it wasn't easy as I had to drop the pan and pull the valve body...runs like a top now!
