Hello to all. I have been working on trying to solve a transmission problem of a 2005 beetle with the 09G transmission. At first the problem was very harsh shifts from 3rd to 2nd gear and after reading a whole lot of discussions on different forums, I replaced the valve body with a rebuilt one. After the installation and filling up with ATF (following the procedures from the 09G service manual) I have noticed that when I put it in D, it will not engage 1st gear and after a few seconds it engages 5th gear. It will not downshift or upshift. I connected a scan tool and got the error code for the transmission output shaft speed sensor (signal implausible). I cleared all the codes and tried running again and it still gives this error code. I scoped the wires of both the input shaft speed sensor and the output shaft speed sensor at the TCM terminals and I get well defined square wave signals. The output shaft signal will show only when the wheels are turning (vehicle on the lift). I took a short video of this behavior so it will be easier for others to see the problem. Can anyone help me out with this?
09G abnormal shift - YouTube
09G limp mode (?) - YouTube
