hi guys first post. got a beetle with cel light but no fault code anybody else experienced this? if so what was the fault? thanks. also got traction light on dash
This should not happen.
If the SES/CEL/MIL lights, there should be one or more codes and Freeze Frame data.
What tool are you using to try and read codes?
Have you used the tool on other vehicles successfully?
You do know that the ignition has to be on and/or the engine running to read codes?
Does your car have a factory or aftermarket radio?
Make sure the traction control is not turned off, check the button below the radio.
A standard OBDII code may not help with a Traction Control system that is in error.
