My car has the following error code (cel)
17988 P1580 Throttle Actuator B1 Malfuction
I have cleared the code with my Vagcom only to have the cel return in 50 - 150 miles later. Car runs fine...what needs to be cleaned or replaced to eliminate this cel? :confused:
Thanks in advance,
Jeff
You might start with cleaning the throttle body and doing a throttle body alignment procedure with a vw specific scan tool like vcds. In the past, we have had some members; having electrical problems with the plug and wiring harness, as well.
