I recently purchased a 1998 TDI Beetle with 86,000 miles on it. Had the timing belt replaced immediately as I was informed they were notorious for destroying themselves before the 90K maintenance. About 800 miles after the timing belt was replaced, the check engine light came on shortly after starting. I stopped the vehicle, restarted, the CEL came on after about 30 seconds. I would estimate about 10-12 starts before the CEL started appearing, the car was slow to start but only when it was hot. Cold start it fires up immediately, warm start it cranks for 5-6 seconds before firing (but never fails to fire). CEL now comes on every time, about 20-30 seconds after start up.
I got hold of an ODB-II reader and checked the codes, I got the following:
01237 - Fuel Shut-Off Valve (N109)
Did some more research on this and other forums and I found a lot of info suggesting this was most likely the fuel pump relay or the fuel pump itself. I was able to source the fuel pump relay online for $20 (New, Volkswagen original part!) so I thought why not try it. I found many photos and directions online showing the location and access to the relay panel so yesterday I did the contortionist trick to get to the relays above the clutch pedal and imagine my surprise when I found the '409' fuel pump relay is not present in my vehicle, see here:
https://www.dropbox.com/s/koupk1wunjbddoy/No Fuel Pump Relay.JPG?dl=0
This is opposed to the photo I found online:
https://www.dropbox.com/s/kx3daj6ljtf99wz/relay one.jpg?dl=0v
So, clearly I'm missing something. Before I go too far down the rabbit hole, can anyone tell me, is my 1998 TDI Beetle supposed to have the 409 fuel pump relay? If I am supposed to have one of those and I don't, how is my car running?
Any insight greatly appreciated before I start 'fixing it until it's broke'
