1 - 1 of 1 Posts
The driver's side headlight on my 1998 NB coupe base, has a very limited range of adjustment up. Adjustable down and side-to-side fine. Is there a fix for this other than replacing the headlight? If not, what do you recommend for a replacement? OEM (VW), OEM (not VW) or an updated aftermarket light (type, make, source if you've done it)?
Thanks
1 - 1 of 1 Posts
