Hi everyone
Im new to vws, hoping someone can help point me in the right direction. I found a 1998 beetle 2.0 102000 miles, that i might buy, if I can figure out whats wrong with it, will crank but wont start, I have noticed that the fuel pump is wired directly to key and does come on, and stays on all the time, so not sure if it builds pressure, they cut the light blue wire to the pump and wired it to the key, I guess it did run before battery died, it will start with starting fluid as long as I keep spraying it, and stay running. the rpm guage works when cranking motor, I can hear the gas moving at the fuel regulator.
codes are
p0102
p1225
p1226
p1227
p1228
p1451
p1421
p1425
p1472
most of them are short to ground, and from reading forums it points to fuel pump relay, I did not change the relay or regulator because its not mine, could the regulater be bad and will not build anough pressure? any input would be helpfull before i make a decision to buy a non running beetle
thanks
codes are
p0102
p1225
p1226
p1227
p1228
p1451
p1421
p1425
p1472
thanks
