So my daughters yellow bug has been running great, except for when it is started in the morning.
If you try to start it normally, not a chance. Holding the peddle tight to the floor and turning the key at it will fire up..Smokes a bit. After a bit of rough idle on start up it runs good.
Throughout the day it will start fine without any effort.
So what is happening when the car sits for 8 hours that is causing it to flood? What should I check to isolate it. Im thinking a bad injector???
