Thank you to all the great info I've found on this forum. I've recently bought a 99 NB (GLS, 2.0 5sp man) for my daily driver/fun car. It's been great, a few minor problems this site has helped with, but I've got an issue I have'nt been able to get much info on.
I'm getting a fluid dripping from the lower driver side radiator. It doesn't appear to be coolant, as it's oily, but it is clear and not engine oil. I though maybe it's power steering fluid, since the resivoir is nearby, but I don't see any leaks from the hoses (that I can see). Fluid is in the actual radiator fins and is collecting on a flange/piece at the radiator. I leak about an half ounce after driving for 10 miles to or from work. What leaks out evaporates after a few hours.
I have minor issues shifting (getting it into the right gear while driving), I'm suspecting I may need to change tranny fluid or adjust linkage. I don't think its gear oil as it's odorless and clear. PS fluid isn't low, no problems with brake, clutch operates well, no grinding, shifts 1st to reverse and back quickly with clutch.
Does tranny oil or PS route through the bottom of the radiator for cooling?
Can I eliminate brake fluid as not routing near the area?
I appreciate any insight.
