p roks 99beetle
Anyone know a site where I can find oxygen sensors for a decent price? Both of mine went bad and need replaced asap. Thanks in advance
I would stick with quality oem brands like Bosch; you can use Bosch's parts finder to determine the right 02 sensors for you particular car.
Look up the parts here using the Bosch vehicle part finder:
Bosch Vehicle Part Finder
Bosch 02 sensors; should be available at your typical local parts store (e.g. autozone, orielly's, pepboys etc.) or online from a many places.
Bosch parts finder results:
16121
Oxygen Sensor Upstream before the cat
(AEG Eng. Code)
(check your vin # to determine which downstream 02 sensor is correct below)
16213
Oxygen Sensor Downstream after the cat
To Chassis # 1C..X..460 000
(AEG Eng. Code)
16132
From chassis # 1c..x..460 001
(AEG Eng. code)
