1999 Beetle Part Out- Blue-Good Body! Central Florida
1816 Views 14 Replies 9 Participants Last post by  SEABEECM1
12
Big stuff will have to be picked up in the Deltona, FL. Or I can bring to the UCF area during the week.
I bought this car as an engine donor for a Mk1 Cabriolet.
All pictured is available with the exception of the shifter.
All body panels are rust free, dent free and mostly ding free.
Suspension is shot. The bushings or ball joints were so worn out it was pretty scary to drive. The wiring harness is pretty hacked up at this point. No engine components are avialable.
Prices are obo. Inquire about anything thats obviously still on the car that I didn't mention.
Exterior:
*Hood-$45
*Front fenders/bumper cover- I think the bottom of the grille opening is torn. $50 for the whole thing.
*Door/doors, complete. HAND CRANK WINDOWS! $50 each.
*rear fenders/bumper cover- $80 for all since its a pain to take off now.
Interior:
I dont have the glove box section of the dash, but I do have the glove box door. All the plastic and rubberized panels need a cleaning, and have some nicks and scratches as to be expected.
*Dash top panels- $30 for the set
*Center section(radio and HVAC control section)-$15
*dome and ring around the speedo-$15
*Complete Dash- $120- Will have to discuss what "complete" means though.
*steering column clamshell-$20. No cracks
*Seats- Dark cloth. Driver has a hole thats covered in black duct tape. $100.
*Carpet, black- $25
*Monster Mats, set of 4- $50
*door panels- fronts have a bit of wrinkling. Rears are good. $20 each
*Turn signal stalk- $20
*Switches: Headlight, rear window defrost, etc 8$ each.
*front air bags- $40 each
Mechanical:
EKG 5 speed transmission- 150. Can ship.
Flywheel, single mass- $40
Radiator fans- $30 each
Radiator- Ding on top, some rubbing from the fans for some reason, but worked- $25
Fuel pump and sender-local only- $30.
1 - 15 of 15 Posts
Sent you a PM to get shipping/payment details for the Dash center section. Thanks for offering your leftovers up to the Org first!
By the looks of the manual window crank, this was a GL, with a 2.0 engine, right?
Was hoping it was a 1.8t. desperately need a manual from a 1.8t.
All the best on the sale.
Yeah it was a 2.0. What's wrong with your box? Strength wise they are the same. To install just depends if you have 100 or 108mm flanges and if you have an early or late shift tower. But all that is easy to transfer.
other than that the gearing might be a little different.
But if your current box is howling tunes of imminent death, even if the gearing is slightly differnt you can atleast drive the car.
Im gonna send you a PM because I have a list of things that I need...:)
Yep, the gearing is different on the 1.8t manual trans.
My bug has an automatic transmission that failed. For the price of a Russian roulette valve body rebuild, I can do a 5-speed swap AND pocket the savings. Plus I'll have a much more dependable vehicle....win win.
With the history of auto trans failures, you should be able to sell it.
Yep, the auto's are pretty horrible.
Front fenders and hood are pending, dash center section pending(part with the AC controls and holds the radio), and some little knick knacks not mentioned in the ad are sold.
Do you have the lower center dash, the piece that houses the hazard and defrost switches? Also, do you have the power door lock switch from the passengers door?
Sorry I was slow to respond. Not getting notifications from the site.
The car(and trans I would assume) had 175 or 180K on it when it was parted.
Yes, I still have the housing for the lower center dash, and the doors are still intact.
parts
hello....
You still have the car for parts sale ?
i am interested in the front seats cloth (only) and rear too and the parcel tray.....have pics ?
Thanks
Aldo
parts
hello....
Thanks
Aldo
1 - 15 of 15 Posts
