What could cause cyl 1 to lose compression ? I know the basics of the gas motors . Just hoping for a different answer
what testing has been done and what were the results?
The code it sent me was a misfire on cyl 1 . I did a comp test on just the 1 cyl and got only 30 psi.
That's very low, yes I am reading; the vw factory service manual spec is:
background image Compression Check:
Specifications
New ...................................................................................................................................................................................... 10 to 13 bar (145 to 189 psi)
Wear limit ................................................................................................................................................................................................ 7.5 bar (109 psi)
Maximum permissible difference .. 3 bar (43.5 psi)
I would also do a compression test on all 4 cylinders, so you have a full scope of what's going on.
