Hi All
Great site ,I have an issue with my 1999 Beetle 2.0L it shift well when driving but when reducing velocity if shifts hard it has 83000 thousand mile and still going. I have thought about changing the transmission control module but just want to be sure that whats wrong.
thanks all for any help you can provide.
David from a rock in the middle of the sea.
Based upon the year of your car; I would assume you have a 4 speed 01M trans. These are known; to have worn valve body and solenoids that stick. Many here; have had success with installing a rebuilt valve body and a fluid change to fix the shifting problems.
Here is a site; that explains the typical problems, diy install info, testing info and rebuilding valve body services for the 01M:
Look at the "trans faq" and "services: 01M valve body repair":
Kansas City TDI
Keep in mind; this is just one, of many places that offer valve body rebuilds but most of the typical troubleshooting and repair info, about 01M is on his site.
