You probably want to start with the basics. There are 2 steps you should take now. One is to get a scan for any codes. The other is to change the transmission fluid and filter if it has not been done within the last 30,000to 40,000 KM.
Do the code scan first because that might indicate valve body problems. Replacing the valve body is relatively easy to do when you change the transmission fluid.
