I got vw nb 2003 turbo S 109k miles 6sp .
I got new Autolite-Xp-Iridium/Spark Plugs today and installed it. When I removed the coil packs id did not drop them. Right after I started to drive and engine check light started to flash and car drives like misfires.
it had misfire on 2 and 4 and no other codes. I removed and re installed 2 and 4 coils and check the cables. Still same problem. Do I need new coils?
Any ideas.
Thanks for your time
No NB Yellow Trifecta :(
Off the top of my head I would say your NB is finicky; replace with OEM plugs and see what happens. All of my NB's act that way if I use any other plug, so I always use the stock plug. I have no idea why mine act that way, they just do ... :confused:
I swear...I get posts deleted or something. Definitely posted a reply last night, saying that it might not like the plugs. Try NGK or Bosch.
Ok. No problem I saved the old ones. Let me go do that and I will let you know.
Thanks
Nope. Did not work. I am putting new coils on 2 and 4 in a minute to see whats going to happen.
Ok I replaced coils on 2 and 4 with duralast C1394 and its working now. But I still have the old plugs in and I have 4 plugs that I don't know if I can return. What should I do? Put this ones in?
I think the coils were about to go and it has nothing to do with new plugs.
And is this a good Vag-Com cable to buy VAG-COM USB Vehicle CAN Bus Cable with Software CD [E18378] : BestOfferBuy.com, Buy DVD, Shop for PC accessories, Discount MP3 Players, Bargain Deal for Surveillance Equipment, Cheap R4 for NDS, X-sim Unlock
Thanks
Discussion Starter #8
Yes it does connect to Pc(Laptop). And read and erase codes and more!
Product Description
- Model: HEX USB CAN VAG-COM for 805.1
- Compatible with the newest cars which require a direct CAN connection for diagnostics including all Golf-5 platform cars and latest Audi A3, A6 and A8,Q7,etc.
- Protocol timing indistinguishable from a real VAG/VAS tool. Works reliably even with "difficult" control modules such as the 1991-1994 1Z Audi TDIs and the 1993-1994 Audi 2.6L with Hella ECU.
- Built-In VAG-Saver functionality -- instantly alerts the user if either the K/K1 line or the L/K2 line is shorted to Ground or Vbatt
- USB connector plugs into most modern laptops!
- Full support for dual-K lines found in "new" (B6/8E chassis Audi A4 and 2002+ Audi A6 -- no VAS-6017 required -- no manual switches!
- Fully backwards compatible with older cars using a single K-line or K plus L
- Bi-Color (red/green) status/activity LED
- Function all of, support the car type to 2007
- Diagnostics Type including:
- All Golf-5 platform cars (A5 platform) including:
- 2003+ VW Touran (1T chassis)
- 2004+ VW Golf (1K chassis)
- 2004+ VW Caddy (2K chassis)
- 2004+ Audi A3 (8P chassis)
- 2004+ Seat Altea (5P chassis)
- 2004+ Skoda Octavia (1Z chassis)
- 2005+ Seat Toledo (5P chassis)
- 2005+ Golf Plus (5M chassis)
- 2005+ Seat Leon (1P chassis)
- 2005.5+ Jetta (1K chassis)
- 2006+ Eos (1F chassis)
- 2003+ Audi A8 and A8L (D3 platform, 4E chassis)
- 2005+ Audi A6 (C6 platform, 4F chassis)
- 2005+ Audi A4 ("B7" platform) (some control modules)
- 2005.5+ VW Passat (B6 Platform, 3C chassis)
- 2006+ Audi Q7 (4L chassis)
- 2007+ Audi R8 (42 chassis)
- 2007+ Audi TT (8J chassis)
- 2007+ VW Touareg (7L6 chassis) ("facelift", built after Nov. 30 2006)
- Packed with driver CD
