21 - 23 of 23 Posts
Still looking for a fix for my AC problem. Where does the compressor get it's power from and where do the wires go from the fan plug (4) wires? I'm lost, found color coded wiring but for an earlier year with 2 fans, any suggestions? I have the required amount of Freon and replaced just about all parts in the system but the fan with the control module, did by a used one, it didn't work either.
Has any one found a solution for this? I have a new fan/module (single fan unit as other mentioned) and also a new coolant temp sensor. Car runs great, but the fan does no come on with either AC or higher coolant temp. There is power at the fan and the 4 wire switch next to starter has power as well and no corrosion anywhere (southern car). Any help would be appreciated.
What a bummer been trying to find a fix for my 2006 nbc same issues no fans or AC just bought a new fan & controller ill get back to y'all
21 - 23 of 23 Posts
