So I am performing a new stereo install and a repair of the fan switch in my 99NB. When I removed the old stereo and got the other stuff (like the fan switch assembly) all out I noticed I had two antenna connectors. Both are euro-din style, and one is wrapped with the factory wire harness wrap, the other not but it has VW marking on it. They both look legit, they both look factory.
I don't remember which one was hooked up (I was removing them semi-blindly, not thinking too much at the time).
Any ideas or recommendations?
Attached are a couple pics:
Wife's 01 1.8T mechanic
Just use a length of spare wire and your OHM/continuity setting on your digital multimeter to check for continuity between the connector and the antenna base. No need to drop the headliner.
