I have just purchased a 2000 1.8 Turbo with 10,800 original miles. The service history on the car (Carfax) shows all service was performed by a VW dealer. Oil changes etc were done on an annual basis (average 900 miles per year). The car was garage kept and shows zero wear inside and out.
My questions:
Timing belt - Should the timing belt be changed as it is 12 years old even though it only has 10K miles on it?
What other service items besides belts and hoses should be checked on this car? I plan to check and if needed replace all vacuum hoses, coolant lines, belts etc, but do not know if any sensors or what else should also be changed out while at it?
I have already ordered new tires for the car as they are the original tires, while no dry rot etc they are 12 years old but show almost no wear at all.
The door panels fabric has come loose on both doors, any pointers on the best place to get purchase replacements?
The sun roof sliding fabric covered panel also has some fabric sag, any pointers on where to purchase a replacement would be a great help too.
There are small pieces of thin black / grey foam coming out of all of the interior dash air vents when the AC system is turned on high. Any idea where this could be coming from and is it worth replacing the failed foam part?
So if you were me and were going to put your daughter in this car (her first car) what would you recommend be serviced checked etc please.
Thank you all in advance
Mark
My questions:
Mark
