Found a cheap Beetle that cranks but will not start. 124,000 miles. First question: if the timing belt is broken then will the vehicle still crank? Anything else I should check first?
Thanks, Bear
Thanks, Bear
what years had the trans trouble?Just be careful about a cheap college car!!!
More info, I see it is a 2000, what motor & transmission.
Except for the timing belt and bent valves, most items are pretty easy to work on. But if you have an automatic car, watch out, MANY problems with the automatic, not likely to leave you stranded, but will give you a lot of problems.
Not sure I will let me daughter take the 2003 GLX to school or not, I need to know I can trust it.
Unfortunate answer is - Yes!what years had the trans trouble?
Sorry just learning the forum thing....So do I start a new thread?????Tatonka:
Please "Stick" with one post or "Thread" regarding your issue. Having more then one trying to resolve the issue can get confusing.
S-
