The transmission lever/gate on my TDI is getting either loose or worn. The car has 107k miles but the gate notch, especially for [D]rive is loose and tends to popout into neutral if bumped even the slightest. Attempts to gain access to the inner workings involves removing the Tee handle by pushing the sleeve down and then pushing in the button...it should come up and out. On mine, no such luck...it is solid and does not budge. Anyone have a solution?
