This thing is driving me crazy! Really, i would have to say these cars are junk. Soooooo many problems. I could go on and on.Yesterday the ac stopped . We replaced everthing a few months back but seemed to be weired after that. The fans are spinning but the compressor is not unless you shut it off, wait, then start it back up. Read up a bunch on here and leaned towards the fan control modual. I have 2 parts cars .the first one blew up afterthe oil all leaked out of the seal between the oil cooler and block .the second one i bought to replace the interior , andsunroof and just to have parts. So i hooked up another fcm. I didnt mount it cause i didnt feel like removing the battery and tray and whatever else is involved. Is there an easy way to get to the bolts. The one i took off the parts car had all that removed allready. This morning we drove it about 15 to 20 miles and the ac stopped again. I pulled over and tapped on the fcm and it did nothing so i kept driving maby another 10 miles and the red light was flashing so i pulled over and the plastic tank was bubling. Let it sit put more water in it .only took a little. And drove all the way back home without a problem except it pings a little like it is to hot and the ac dont work. I put gas in it yesterday and thought maby it was crappy gas cause i noticed it pinging yesterday but the light never came on. Maby it is just running way to hot? Maby the thermostate is bad but im not sure why i was able to make it all the way home then. In the last three weeks the elec water pump up front broke at the plastic dumping all the water leaving my wife stranded. Then the plastic peice that has the line in it that goes to the top of the plastic tank broke leaving her stranded.i made a new one out of metal. Then the peice that holds the temp sensor broke . Found this out at home. Sweet. This car has 97000 miles and the watet pump has been changed. It has the metal impellor. It runs fine except the turbo doesnt work, thats another prob. Is it the thetmostate causing this?
