I'm having an issue.....EPC light is on and my car won't even turn over nonetheless start. Windows don't work just fan blower dash lights head lights and radio. Replaced ignition switch and battery. Please help if can. Can't afford tow right now to dealership.
Just in case you check back...
Common problem with the EPC and Jettas of your timeframe is a pressure regulator hose. Super cheap fix.
The EPC light is connected to a sensor in the block. Open the oil cap and release the pressure. If your light goes out, the sensor is bad, and you have no real issue. If you replace the sensor you will have to reset the computer (leave battery unplugged for a while) so it re-initiates the check for faults.
