I've been having a problem with my 2001 2.0l (automatic) that when it gets to about 210 miles or 1/4 tank it will stall from fuel starvation.
If I'm on the freeway this can manifest itself as a loss of power then re-surge as the fuel supply returns.
However if at slow speeds on city streets it can completely die out and after a minute or two and a few tries, it will start up and continue on.
It's like some sort of fuel feed valving is changing and causing the line to go dry. It fairly consistantly happens near the 1/4 tank mark.
I was having this problem a few months back and changed the fuel pump. I thought it solved the problem but it seems to have returned.
I can't be the only person to run into this.
Thanks,
Jamie
Thanks,
Jamie
