Hi guys!! I'm in desperate need of some help. Usually I am pretty good at DYI repairs on this bug, but this time Im stumped.
Here's my story. I have a 2001 Beetle 2.0L non turbo 5-speed. And a few weeks ago I realized that it was getting AWEFUL MPG... About 20 if my math is right... Now I have another bug, 1999 Beetle 2.0L non-turbo 5-speed (basically the same car) that gets 35+ MPG...
The check engine light has been on but to be honest, I think it's been on since the day I bought it. But yesterday, I was driving and all of a sudden I have NO power... It didn't stall, but it had no torque or acceleration... At first I floored it and powered through it, but then it happened again and eventually with my foot to the floor and the engine RPMs just as sluggish as possible tried to come up but just couldn't.... I ended up having it towed home...
I guess I should also tell you that last week I was having an issue where when I was downshifting for a turn and the RPMs would get low the engine would stall... I found a broken vacuum hose connected to the EGR valve and replaced it and that seemed for the most part to fix that problem...
Today I attempted to drive it again, it starts and idles fine, put it in Reverse, and it's got good power and torque, put it in 1st, at first it felt okay, until I tried the slightest incline and back to square one....
So I grabbed a code scanner to see what the CEL was for and here's what I got:
**P0102: MAF or VAF Circuit Low Input
**P0134: O2 Sensor CKT No Activity (Bank 1 Sensor 1)
**P0139: O2 Sensor CKT Slow Response (Bank 1 Sensor 2)
**P1420: Secondary Air Injection Control Module Electrical Malfunction
**P1255: Engine Coolant Temperature Sensor Short to Ground
**P1296: Cooling System Malfunction 17704
**P1582: Idle Adaptation At Limit
**P0112: IAT Sensor 1 Circuit Low Input
**P0137 pd: O2 Sensor Circuit Low Volts (Bank 1 Sensor 2)
**P1580 pd: Throttle Actuator B1 Malfunction
MIL ON
MONITRS
4 Inc
Catlyst
Evap
Sec Air
02 Snsr
4 Ready
Misfire
Fuel
Comp
02 Htr
So basically what Im saying is HELP!!!
... Or rather any insight would be greatly appreciated...
Thanks in advance,
Chris
Sent from AutoGuide.com App
MIL ON
MONITRS
4 Inc
Catlyst
Evap
Sec Air
02 Snsr
4 Ready
Misfire
Fuel
Comp
02 Htr
Thanks in advance,
Chris
