Hello,
I’m new here, and new to working on beetles/VW.
Little bit of what happened before doomsday. So it’s my girlfriends car, and we live in TN and it’s getting cold fast. Her blender doors were bad and I had to remove the HVAC to fix them. Good news the heat and ac works now! Bad news, the car’s tachometer no longer works, and it won’t shift above 3rd ger. I have a flashing red oil light, flashing red brake light, solid yellow ABS light, and Airbag Light.
I’ve taken the dash back apart and checked for obvious torn/scraped/exposed/cut wires and I didn’t notice anything, checked all fuses, sanded the grounds under the dash and the two in the ECU/TCU area. I’m at a complete loss, the car did not have any of these problems before. Tested Amp draw while key is out using multimeter with negative terminal disconnected, came out to be around 480mAh.
Could this possibly be a bad ECU?
Sunday,15,December,2019,17:40:50:05940
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20190930 DS308.0
Mileage: 230500km-143226mi Repair Order:
Chassis Type: 1C - VW New Beetle (1998 > 2010)
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
Mileage: 230500km-143226miles
Address 01: Engine Labels: 06A-906-032-AVH.lbl
Part No: 06A 906 032 EB
Component: 2.0l R4/2V G *3667
Coding: 00003
Shop #: WSC 00066
VCID: 629DA9202D5EC257BF3-5160
4 Faults Found:
18058 - Powertrain Data Bus
P1650 - 35-00 - Missing Message from Instrument Cluster
18044 - Powertrain Data Bus
P1636 - 35-00 - Missing Message from Airbag Controller
18034 - Powertrain Data Bus
P1626 - 35-00 - Missing Message from TCU
18057 - Powertrain Data Bus
P1649 - 35-00 - Missing Message from ABS Controller
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 JF
Component: AG4 Getriebe 01M 4833
Coding: 00000
Shop #: WSC 00000
VCID: 7DA7FA5CB4E01DAFA21-0962
6 Faults Found:
00777 - Accelerator Position Sensor (G79)
27-00 - Implausible Signal
00660 - Kickdown Switch or Throttle Position Sensor
00529 - Engine Speed Signal Missing
35-00 - -
00545 - Engine-Transmission Electrical Connection
31-00 - Open or Short to Ground
01314 - Engine Control Module
49-00 - No Communications
01312 - Powertrain Data Bus
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0004097
Shop #: WSC 00066 000 00000
VCID: 2A0D010010EE5A17B73-5184
4 Faults Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
012 - Electrical Fault in Circuit
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
00285 - ABS Wheel Speed Sensor; Front Right (G45)
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 25 AIRBAG VW5 0E 0004
Coding: 12853
Shop #: WSC 00066
VCID: 3537227CCC5005EF2A1-4B3C
3 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
00588 - Airbag Igniter; Driver Side (N95)
32-00 - Resistance Too High
00589 - Airbag Igniter 1; Passenger Side (N131)
Address 17: Instruments Labels: 1C0-920-xx0.lbl
Part No: 1C0 920 906
Component: KOMBI+WEGFAHRS. M73 V03
Coding: 03232
Shop #: WSC 07458
VCID: 5EE59DD01926E6B79BB-4B1E
Subsystem 1 - Part No: Ident
Component: Nr. Wegfahrs.:VWZ5Z0YN061567
Ident.-Nr. Wegfahrs.:VWZ5Z0YN061567
1 Fault Found:
37-00 - Faulty
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN V032
Coding: 00006
Shop #: WSC 00066
VCID: 70B9D368F3B260C7397-4B1E
1 Fault Found:
37-00 - Faulty
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AR
Component: 7S Zentral-SG Komf. 0001
Coding: 00256
Shop #: WSC 00066
VCID: 0E45AD90894616374BB-4B1E
Subsystem 1 - Part No: 1J2959802C
Component: 7S Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J2959801D
Component: 5X Tõrsteuerger. BF0002r
2 Faults Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1C0 035 157 D
Component: Radio DE2 0005
Coding: 06033
Shop #: WSC 03325
VCID: 1D67DADC54A0BDAFC21-51CE
No fault code found.
End----------(Elapsed Time: 03:41, VBatt start/end: 12.8V/12.2V)-----------
You have all the codes recorded, did you just try clearing them and see what comes back? Did you turn the ignition on with all that stuff in the dash disconnected while fixing the blend doors?
Yeah I cleared all the fault codes using VCDS, they all come back immediately.
