I'm having the clutch and flywheel replaced on my 2001 Beetle. Is there anything I should have done at the same time while the tranny is pulled? Thanks for the help. Jeff
Check the DMF, if whoever is doing it does a lot of VWs they should know to check it, but it often gets over looked. Never mind, I guess you said they were already replacing the DMF.
If there's nothing really wrong with the car then no.. nothing else needs to be done when the transmission is pulled.
I put new gear oil into my transmission (and painted it!) since it is a 2000 so I figured why not. Didn't really make a difference though but I like to keep all the oils as fresh as possible.
