I've got two electrical problems with the left rear of my daughters 2001 Beetle.
First, she was told that the left rear side marker was out. I confirmed this, replaced the lamp and nothing. The contacts were rusty though so I pulled the connector, checked the resistance and found one of the leads was bad. I went out, got a replacement and still nothing. Finally, I checked the voltage and got .019V - the right side marker (which works fine) is showing 10.9V. So clearly a problem there.
However, along comes the second issue. I pulled the left tail light housing out to get a better look at the harness and get my bearings. After putting it back together, I found the left rear running light (the filament always lit when the lights are on) is no longer working. It was fine before i pulled the housing and is now only getting .24V.
The left brake light and turn signals work fine. The license plate lights and everything on the right rear are fine. As I'm writing this, it occurred to me that I didn't check the 3rd brake light so I'll have to post an update regarding that.
So any ideas on what's going on here? Given both are providing a bit of voltage, I'm thinking a grounding issue but just don't know the rear wiring on this car very well. Thanks for your time and any input you can provide.
Dan.
Dan.
