Dreams Come True
When first got car when rolling driver power window up it would go up and down, but when rolling up would need to be pulled back would not go up straight. Well now the window gets stuck or falls down. button will not roll up and down. Think it helps get it unstuck. I hear the motor when I hit the button. Not sure it sounds that great. What should I do? I know theres screws under door panel and behind cover on door handle. From there I'm clueless. I don't want to break anything. Got my radio working so now time to fix this. Advise?
It's the dreaded window regulator failure. If you are not mecanically inclined, you can have it done at the dealer, or an independant VW shop.
The VW regulators were so problematic, VW gave them a seven year warranty. Unfortunately, you are now passed that. :eek:
Good luck to you!
STILL Can't Stop the Rock
If you DO try to do it yourself, beware of kits on ebay. They are not accurate to model year and you'll wind up going OEM anyway. Dealer or ECS, is all I'll say
