Hello All
Enjoy working on my wife's 2001 1.8t, 'soft blue' I'm told :)
In any case, through a combo of VAG-COM and visual inspection,
I've found that her wastegate actuator is really brittle, has at least a small hole, and is definitely in need of attention.
It also appears to be PLASTIC? Is this correct?
All the replacements I can find are metal, which I assume is a better idea than patching/fixing existing?
It seems like a really flimsy part.
Any/all advice appreciated. I'm no pro :)
Thanks
Discussion Starter #2
more info
Should have mentioned:
Only real symptom is rough idle and VAG COM 17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
Car is very much drivable.
