I have a 2002 Beetle with an automatic 4 speed transmission with 107,000 miles, and almost every time when I shift from 2nd to 3rd gear, the car will lurch forward and the rpms will shoot up. There are no transmission codes. Could this be fixed by changing the fluid, or is this a sign that my transmission has finally gone, or is it something different entirely.
These are pretty typical issues, you would need to scan for trouble codes to start your troubleshooting process; what scan tool are you using?
I’m using an OBD eleven and scanning all the modules, but still get no codes.
I am also having his issue, buy my issue is with 1st and 2nd gear it is a 2000 VW golf, and i have a P1128 code , rpms rise and engine jerks but only twice then normal until I come to another stop , also twice the car wouldn't turn on unless I would rev the engine at start up but there was about a 2 month gap between both of those times
