I was driving down the highway and all of a sudden no gas pedal, I got pulled over to the side of the road and shut off car, not so sure that it was already off, I turned the key off. Waited a few minutes, no start. When I try to start it sounds like its not engaging only a fan like noise, towed him home and ran codes I got the P0011 code camshaft sensor. I googled all the symptoms and have seen very different results. I can still hear the fuel pump run when I open the door, so dont think that is the issue. I peeked in the Timing cover area and the belt is still intact and tight. Hoping that it is just the camshaft sensor. Any ideas?
16395/P0011/000017 - Ross-Tech Wiki
http://api.viglink.com/api/click?fo...orums&txt=16395/P0011/000017 - Ross-Tech Wiki
I would start with some basics:
1. check the timing marks and see if they are all in time; possible timing belt or component failure (worst case scenario bent valves). Any teeth missing, belt loose, hydraulic tensioner leaking or idler pulleys bad/seized? When the valves are bent; there is no compression and your starter/engine will sound weird, turns faster and the engine won't start. Checking and alignment info:
Volkswagen Workshop Manuals > New Beetle Turbo S L4-1.8L Turbo (AWP) (2002) > Engine, Cooling and Exhaust > Engine > Timing Components > Timing Belt > Component Information > Service and Repair > Procedures > Page 1557
http://api.viglink.com/api/click?fo...gt; Engine, Cooling and Exhaust > Engine &...
2. check cam position sensor; we have had some members that they have broken inside. Testing and inspection info:
Volkswagen Workshop Manuals > New Beetle Turbo S L4-1.8L Turbo (AWP) (2002) > Powertrain Management > Sensors and Switches - Powertrain Management > Sensors and Switches - Computers and Control Systems > Camshaft Position Sensor > Component Informati
http://api.viglink.com/api/click?fo...gt; Powertrain Management > Sensors and Sw...
Check things out and we will go from there.
About the camshaft sensor...
A few months back, when "Hitler" was having limpmode problems, I got a camshaft sensor, and a crankshaft sensor from Amazon for a few bucks. They worked. Of course my big issue was the $1100. I spent on a defective throttle body, which I recently replaced for $99. from Amazon too.... It is running like a new one! I will never get all the labor I paid for back, but I will get a refund on the bad throttle body off the warranty. Good luck to you.
I will have a look at the timing marks when I get the next chance, I have already ordered a new camshaft sensor, what is the difference in camshaft sensor and crankshaft sensor, I read different things. I know where they are located but just making sure that the camshaft sensor, which is what the P0011 code is for. Thanks
Based upon the Wiki: looks like you need to test the Camshaft Adjustment Valve 1 (N205) valve:
https://www.google.com/search?q=p00...=chrome&es_sm=91&ie=UTF-8#q=p0011%testing.pdf
Possible Solutions
Check Camshaft Adjustment Valve 1 (N205)
Check Fuel Pump Relay (J17)
Check Mechanical Timing
(check timing marks)
16395/P0011/000017
Contents [hide]
1 16395/P0011/000017 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
1.1 Possible Symptoms
1.2 Possible Causes
1.3 Possible Solutions
1.4 Special Notes
Possible Symptoms
Power Loss
Possible Causes
Camshaft Adjustment Valve 1 (N205) faulty
Fuel Pump Relay (J17) faulty
Mechanical Timing not correct, including Chain and/or Belt timing.
Possible Solutions
Special Notes
When found in Engine: 4.0l W8
Check TPL 2010059(RoW)
Check/Replace Oil Sieve in Timing Case (Camshaft Adjuster)
