I just bought an 02 bug, and am having some issues.. The check engine light is on, the acceleration seems slow, and the idle is high. I plugged in an OBDii scanner and it threw 3 codes:
P0722 - Output speed sensor circuit no sign
P0730 - Incorrect gear ratio
P0715 - Input turbine speed sensor circuit
Any advice as to what these mean and how I can fix them?
Much appreciated!
-Claire
I'm sorry, I'm no mechanic. But soon, someone with the right knowhow will be here to give advice. Good luck to you! :eek:
Here's the DTC codes that you found in your ECU's code listing:
P0722: transmission output speed sensor.
P0730: Incorrect Gear Ratio
P0715: transmission Input/Turbine Speed Sensor Circuit Malfunction
Sounds like you've got automatic transmission problems. Not likely a DIY repair; you need to locate a local VW specialist service facility and get your car in the hands of an expert.
