For sale is a 2002 New Beetle with a CLEAN CA TITLE IN HAND.
2002 1.8T GLX
85k Miles
Auto trans
power everything in working condition.
THE GOOD: A ton of new parts with less then 50 miles...
alternator
timing belt/Tensioner
water pump
valve cover gasket
thermostat
vacuum hoses
PCV valve/hoses
radiator fan
coolant hose flange
coolant temp sensor
clean MAF
clean intake temp sensor
and more...i have all receipts and even pictures!
tires are good
The not so good:
I inherited this car from an elderly lady 2 months ago. I have went through it replacing a lot of worn/needed parts. I have a folder of receipts. Unfortnately for me, it is still overheating. I finally had it diagnosed by a European Shop in Old town Temecula, CA. It has a minor head gasket leak.
The car has some left side damage as seen in pics. Elderly lady was not so good at pulling into her carport. If you can look past the damage and willing to fix, this car has many miles ahead of her and will be a great car for someone. It has driven great the little i have driven it until it starts to overheat which then i would shut off and pull over immediately. NO leaks under the hood! I have spent a ridiculous amount of time on this car.Asking $1800 given the new parts it has and lower miles. I non opted the registration as of 10-9-15.LOCATED IN WILDOMAR, CA. Serious inquires please. PM me
