Hi everyone I have a 2003 1.6 petrol beetle it’s developed a rough from from cold start up and even does it when warm . It’s quite loud on idle so checked and found and exhaust leak from the two down pipes meet the exhaust manifold . Checked fault codes and form intermittent fault on bank 1 o2 sensor and a static fault on the egr I checked and found a 10amp fuse that was down replaced it cleared all the faults and they all cleared . But still have this terribly rough idle ? Any ideas 💡 could the exhaust leak be causing this rough idle due to the leak being just after the bank1 sensor ?? Any help will be greatly appreciated
