Fuel wet plugs sounds like too much fuel being pumped into the cylinders for some reason or plugs not firing.
Possible leaking injectors, bad coils, bad coil harnesses/coil plugs, since the problem is persisting after you changed the spark plugs, we can pretty much rule out them as being the cause.
