1 - 9 of 9 Posts
Car loses all power to everything and dies going down the road does anybody have an answer
Hey, can you give us more info (e.g. year, model, engine and tranmission of the car in question)? What is the history of the car; when did this start happening and have you scanned for trouble codes? Most stall/dying issues; tend to come down to fuel delivery or ignition related issues. Give us some background and any codes, full info about the car and we can go from there. Thanks.
It is a 2003 new beetle convertible with a 2.3 and automatic transmission. It has approximately 95000 miles. And the machine I have does not show any codes. This just started yesterday on the 17th. My daughter says it's a loud pop and then everything just dies.
Is it a 2.0? Is it a 4-speed auto or 6-speed?
Can she restart it right away? Does she need to wait? Electrical dies as well or is it just unresponsive? What scanner are you using?
It may be just a 2.0 but I am pretty sure it is a 6-speed Auto. The electrical and everything dies. She has to wait a while and then it will start back up.
  • She also has a loud pop before it dies. It may start and run again after a while but then it does it again.
There was no 2.3 option, so if its non-turbo its a 2.0.
Likely a cam or crank sensor failure. Common. Though I don't know that I've heard of a popping sound before.
Does it run well otherwise? Have you checked the timing belt to make sure that's all in tact?
Discussion Starter #9
Yes it runs fine except when it quits like that. It is a non-turbo.
1 - 9 of 9 Posts
