I bought a 2004 for my daughter.Worked fine for 3 weeks. One morning battery was dead. charged and started.Next morning dead again.Towed to shop. No power to ecm or injectors.all fuses intact.Trying to find a control relay. vw says under hood.Cranks fine. Ideas?
First, have you scanned for trouble codes; that is always a good first step, to see if any are there. It is preferable to use a VW specific scan tool; like VCDS by Ross Tech but if you only have a generic OBD II scan tool, see what codes you find. Has the charging system been fully checked and repaired? Obviously, the battery going dead; every day, is not normal. These cars will go goofy and the immobilizer system, can kick on, if the charging system is low or not working as it should.
Give us more info; about what the repair shop did and what the situation is, what repairs they completed.
A common no start and problem with no power to various parts of the car, is a bad fuel pump relay. This will throw a bunch of trouble codes; as the FPR, provides power to the injectors, many other crucial fuel related control parts. If you buy a new one, stick ONLY with a oem Stribel or genuine VW relay (Stribel, is the oem for VW; the genuine VW part will be marked with the Stribel brand). Aftermarket fuel pump relays; have given people all kinds of problems and many won't work correctly.
The fuel pump relay is marked (409) and located under the dash, you will need to remove the plastic panel, to access it.
Here is the location:
#4 Fuel Pump (FP) Relay (409) (#4 from the top left row)
here are basic testing procedures; for the fuel injectors,
testing for ecm; power checking:
So, give us more background info on the car, repairs done, any testing you have performed and any trouble codes you find, we can go from there. Thanks.
Got a call. was informed radio fuse had failed.replaced fuse car starts and runs fine. I was a diesel tech for an International dealership for 30 years.I saw a lot of weird electrical issues.I am not doubting them it works now but I think its masking the real issue. I don't want to burn time if it runs now chasing a ghost. A tech for Cat told me in cases like this you have to use the "advanced troubleshooting method"I asked what is that.He replied start changing parts. I know the symptom will return at a bad time for my 18 year old daughter. The draw leads me to suspect a stuck relay.Any thoughts?
Basics, did you scan for trouble codes? A bad fuel pump relay; will throw a bunch of "shirt to ground" codes; including the power to the fuel injectors, resulting in a no start condition.
