Hi, this is my first post. When the driver door is opened the window drops ½” to clear the convertible top, but then continues all the way down. After this the driver window-up controls will not function for various amounts of time (usually greater than 30 minutes). Once the window-up function returns and the window is raised all the way to the top, the window can be lowered with the switch all at once or incrementally, but the window-up function stops working, and opening the door will drop the window all the way down again. Removed the door panel, reconnected all the switches, then disabled the window switches one at a time with the thought that the switch was stuck in the window-down position, but had the same results. Tried to reset the memory by raising and lowering all the windows through three cycles (tried both interior door switch and outside key lock methods), but the driver window will not go up. I’ve read that earlier models had issues with the door latching mechanism, but have not seen similar issues with the 2004 model. Not sure of the complications in removing the inner door panel, so have not done this yet. Any ideas on what the problem could be? Thanks.
