1 - 20 of 23 Posts
i'm parting out a nbc its a 2004 w 9500 miles on it, top is perfect, no motor or trans , int or pass door, drivers airbag is good, odometer only says 9500 on it. , lots of parts give me a call, 631-835-3714, car is located in new york, have pics if needed too
Careful of this one ppl! The Seller, I mean.
Do you have the center console? I can't tell if it is black. I am looking for the black center console where the emergency brake is housed.
Thank you.
JYD, Peppy Pepper, Rico,
parts parts
Hi,
You still have the drivers mirror and blinker assembly? How much shipped to st louis mo 63303?
thanks
DropTopDub Extraordinaire
im interested in the following, quite a list. please let me know which ones you have and what you'd like for each. my email is [email protected] if you want to email me. thanks!!- Bret
-motorized painted top flaps both large ones that flip up and small ones that slide forward
-seat belt buckle receivers for both front seats (ones that mount to the center of tunnel
-clear plastic cover for speedometer and black plastic front hood piece (not the pod itself just the piece facing you)
-glovebox door if gray
-floor mats if black
-rubber bumpers on rear deck that the back window rests on when top is down (there are 6, they are about 3/16" diameter cones)
-rear hatch VW emblem (if emblem is nice and bottom center of W swings away to hide keyhole.
-tow hitch painted plug from front bumper
-center arm rest black vinyl top
-door panel gray vinyl molded armrest pieces
-owners manual binder- binder only
-hand screw that secures the spare tire down in the trunk
-rear seat ski pass thru sack
-left side dash vent
-center dash section with vents
-gas flap
-gas cap
-rubber fender protector flap for gas cap
Discussion Starter #16
ok these are the parts i have left
i have complete speedo cluster w 9500 miles on it
all of the dash vents
rear emblem on hatch
gas flap
gas cap
rubber flap
spare tire hold down screw as well
rotor flap
Hi, i need the rotor that lift de flap on th sides, only the center piece not the motor, do you have it??
This is the piece
1 - 20 of 23 Posts
