I just purchased a VW Beetle GLS 2.0L last week and it seems that the transmission may have some sticking solenoids in the valve body. There's a lag followed by a sudden kick into gear that only happens when shifting in the lower gears (1-3). It also hard shifts at times when the automatic transmission is downshifting prior to a stop at a traffic light. It seems to happen less when the engine is still cold.
Would a transmission fluid, filter, and gasket replacement fix this problem or do I need to go ahead and replace the valve body while in there? I'm looking at getting this kit from Blauparts https://www.blauparts.com/vw-beetle-atf-transmission-fluid-change-kit-6-speed.html. Also, is there a fill plug anywhere else other than the actual drain plug itself on the 2005 GLS 2.0L model?
Thanks in advance for your help!
The typical steps would be, to get the car scanned for trouble codes with a vw specific scan tool like vcds by toss tech. Sometimes, a external transmission related sensor will fail causing problems or the external wiring harness; can cause connectivity issues. Those issues, will normally throw trouble codes; aside from that, sticking solinoids in the valve body are common, replacement with a rebuilt valve body and new internal ribbon wiring harness, fresh fluid/filter, has been a successful fix for many.
Ultimately, there are no guarentees, this will fix your shifting problems; as there could be internal issues that require a terardown to find the problemor a total rebuild to fix it. So, that would be some steps to do, before getting a replacement valve body; as always, no guarentees but we seem to have had a high success rate around here with replacing valve bodies with professionally remnufactured and tested units. I hope this helps!
